Spindle taper on Craftsman drill press?
http://www-.luthiersforum.com/forum/viewtopic.php?f=10102&t=10659
Author:  Terry Stowell [ Wed Jan 31, 2007 1:13 pm ]
Does anyone know what the spindle taper on Craftsman radial drill press is?? (circa 1996 or so) I think I need a better chuck, as there's beeen a runout problem
Terry Stowell39113.8853472222
Author:  Greg [ Wed Jan 31, 2007 3:32 pm ]
probably a Morse #2 (most common). You could pop it out and take it with you to tool store to buy the new one. Delta website might confirm taper.
Author:  JohnAbercrombie [ Wed Jan 31, 2007 3:49 pm ]
Once you pop (drive?) the existing spindle adapter out, it might be a good idea to check the runout on the spindle with a dial indicator.
I had a runout problem with my last drill press which wasn't cured with a new chuck and taper adapter.
BTW, some of the simpler/smaller drill presses don't have a removable MT adapter but just have a Jacobs or ?? taper machined on the end of the shaft.
Keep us posted with your progress!
Author:  Louis Freilicher [ Wed Jan 31, 2007 5:07 pm ]
Terry,
If you don't have any luck try posting a question on one of the machinist
forums out there.
Practical
Machinist
Or
The Home Shop Machinist
Author:  Terry Stowell [ Wed Jan 31, 2007 5:52 pm ]
thanks. I took the chuck off and the spindle ran smoothly, but I didnt check it with the dial. If I rotate a bit in the chuck it helps a little.
Grizzly sells chucks but I don't know if it's morse or Jacobs, or what #. It might be in my manual, but I haven't located that yet.I'll check the sites recommended above.
Thanks again
Author:  Louis Freilicher [ Thu Feb 01, 2007 3:04 am ]
Terry,
If you do a goggle search for Morse taper you should find a database of
standard tapers and their small and large diameters and work backwards
from there.
If not PM me the measurements and I can look it up for you.
Louis
Louis405239114.4619328704
